Automatic installation of CMS applications (content management system) in one click
With our automatic installation system, you can install any CMS available in your control panel in just a few steps. Follow this step-by-step guide to complete the installation.
1. Access the Applications section
  • Log in to your cdmon Control Panel.
  • Go to the Manage Hosting section for the hosting account where you want to perform the installation.
  • Within the hosting management section, click on Applications.
2. Search for the desired CMS
  • Within the Applications section, you can click on the application you want to install. You can also go to More applications and use the CMS Search to quickly find your application.
  • Alternatively, browse the Categories according to the CMS type.
    • WordPress: The most popular CMS on the market; you can easily create a blog or landing page. Video tutorial link: WordPress Installation
    • PrestaShop: Designed for creating online stores. Video tutorial link: PrestaShop Installation
    • Joomla: An application designed to create virtual environments. Video tutorial link: Joomla Installation
3. Select and install the CMS
  • Click on the button of the chosen CMS.
  • Note: If this is your first time using the installer, you must accept the Terms of Use.
  • A new window will appear where you can define:
    • Installation location:
      • Hosting root: It will be installed on the main domain.
      • Custom path: It will be installed in a specific folder.
    • Administrator email: It will be used to configure the administrator user (by default, the main user’s email).
4. Confirm the installation
  • Click Start installation
  • The installation will run automatically and may take several minutes.
  • After clicking 'Accept', the CMS administration access details will be displayed.
5. Final considerations
  • You will receive an email with the access path to the installed CMS administrator panel. It will also indicate the administrator username.
  • During installation, website permissions will be changed to 775 and www:user to maximize compatibility with plugins and addons.
  • You can view all completed installations and the generated usernames and passwords in the Installed CMS Log within the CMS management panel.
For more information, you can contact us.
    • How to view the access credentials of a CMS installed in cdmon
      IMPORTANT: Only the access credentials of the CMS installed directly from our panel will be displayed. If you import one externally or perform a manual installation on your hosting, these credentials will not appear in the "Application access ...
    • How to enable automatic updates in WordPress
      In this article, we show step by step how to enable automatic updates from the WordPress administrator. The first thing you need to do is access your WordPress website and go to your site's admin panel. In the left-hand menu, find and click on the ...
    • How to copy the theme from one Wordpress to another
      It is possible that at some point you may want to copy a theme from one WordPress site to another, either because you want to keep the configuration or because you want to use the same files. In this guide, we will show the steps to copy a theme from ...
    • How to migrate entries from one Wordpress to another
      It is possible that at some point you may want to copy posts from one WordPress site to another, either because you want to have the same content on another site or simply keep a backup copy of the posts. In this guide, we will show the steps to ...
    • How to turn off automatic WordPress update emails
      With the Manage Notification E-mails plugin, you can manage the notifications you receive from your WordPress site. Among other options, you can disable automatic update emails for the plugins and themes you have installed. First, access your ...
