Frequent Woocommerce errors and how to fix them
Online sales are currently on the rise, and the demand for having an eCommerce store for any physical business is now a reality.
WordPress is an application that allows you to build all kinds of websites, and of course, it also enables you to create online stores. The most well-known and widely used plugin for this purpose is WooCommerce.
In this guide, we will outline a series of common issues you may encounter when using this plugin, along with a brief solution for each case:
Issues with WooCommerce updates:
Update issues are common in WooCommerce, especially when upgrading to a new version. To resolve this, make sure you create a backup of your website before updating. Then, verify that all your plugins and themes are compatible with the new version of WooCommerce before proceeding. If you experience issues after the update, check the WooCommerce error logs to identify any specific problems that may need to be addressed.
Payment issues:
Payment problems are common in WooCommerce, especially when using third-party payment extensions. To fix this, ensure that the payment extension you are using is updated to the latest version and that the checkout process is properly configured in WooCommerce. You can also check the WooCommerce error logs to see if there are any specific payment-related issues.
Issues with payment gateway integration:
Sometimes, WooCommerce does not properly integrate with the payment gateway you are using, which can cause issues when processing payments. To resolve this, make sure the payment gateway is correctly configured in WooCommerce and that the account details have been entered correctly. You can also try disabling and re-enabling the payment gateway in WooCommerce to fix the issue.
Issues with other WooCommerce plugins
It is possible that a specific WooCommerce plugin may cause an error or simply not function as expected. In such cases, you can check the error log in your control panel, where you may see an error message similar to the following:
WC_Log_Handler_File::get_log_file_path was called incorrectly. This method should not be called before plugins_loaded. Backtrace: WooCommerce->log_errors, WC_Logger->critical, WC_Logger->log, WC_Log_Handler_File->handle, WC_Log_Handler_File->add, WC_Log_Handler_File->open, WC_Log_Handler_File::get_log_file_path, wc_doing_it_wrong. This message was added in version 3.0.
The error may vary, but this log indicates that there is an issue in the code of one of the files related to WooCommerce.
Tax configuration issues:
Sometimes, taxes are not configured correctly in WooCommerce, which can cause problems when processing orders. To fix this, make sure that the tax settings are properly configured in the "Taxes" section of WooCommerce. Verify that the country and region are correctly set and that taxes are being applied properly to the products.
Performance issues:
WooCommerce can sometimes be slow, especially if you have a large number of products or orders on your website. To improve performance, make sure you are using a reasonable number of plugins and that your site is optimized for speed. You can use caching plugins and image optimization plugins to enhance your site's performance.
We hope this information helps you resolve some of the most common WooCommerce issues. If you have any other specific problems, do not hesitate to contact our technical support service.
    • Most common FileZilla errors
      In certain situations, the web FTP manager cannot be used, which is why we recommend using an external FTP client. We recommend using FileZilla, which is completely free. How to connect via FTP using FileZilla It is true that in certain situations, ...
    • Most common Wordpress errors
      WordPress is a CMS application with a wide range of different applications and functions, which means there are also many errors that can be generated by them. In this guide, we show the most common and generic errors that WordPress may display: ...
    • What is and how to fix the ERR_TOO_MANY_REDIRECTS error
      It is likely that while browsing the internet or even on your own website, you may have encountered an ERR_TOO_MANY_REDIRECTS message indicating that there are too many redirects to complete the connection. The error usually looks like this: This ...
    • How to resolve the most common PrestaShop errors
      PrestaShop is one of the most popular CMS platforms for online stores. It offers a wide range of plugins, modules, and themes to customize and add new functionalities to your shop. As usual, while working with the application, error messages may ...
    • WooCommerce: Slow charge for 'wc-ajax=get_refreshed_fragments'
      WooCommerce is the most popular plugin for creating online stores in WordPress. This plugin uses AJAX technology to provide a smooth and dynamic user experience. One of the key AJAX calls is wc-ajax=get_refreshed_fragments, designed to update ...
