In the accommodation ofcdmonyou have a white mark panel so that you can give access to another user and allow them to manage the hosting. The advantage of this dashboard is that the user you provide access will only be able to manage the options you want from the accommodation, and without seeing the rest of the products you have contracted.
In addition, you can also customize its appearance. It is especially useful for resellers or resellers.
Below we explain how to access the white label panel (Management) and the configuration and management sections of that panel.
Access to White Label Panel Configuration (Management)
To access the "White Label Panel" settings, in the 'Basic list of services', you have to click on the option Hosting of the accommodation you want to activate the dashboard.
On the accommodation management screen you have to go to the "Product" section and click on the optionWhite mark panel (Management).
Once the "White Label Panel" option is pressed, you will access the configuration of that panel, where you will find the following sections to set up the panel.
Access data to the White Label Control Panel (Management)
In this section you can see the access data to the white label panel.
Username:access user to the white mark panel.
Password:access password to the white mark panel.
Management Panel:direct link from the control panel for the login window to the white mark panel.
Change username and password:option to modify the user and access password to the white label panel.
Modify colors
From this section you can modify the colors you want to present on the white label panel. Just tap on each set color, in the boxes below, and click onSave new color settingsto assign the chosen color.
Modify the logo
In addition to colors, you can also modify the panel logo.
Here you can modify the image of the white mark panel logo. Just upload one image from "Select file" and then click on Upload image.
Menus management
Using the menu manager you can enable the options you want to appear in the white label panel, you can turn the options listed on or off.
Main FTP configuration:configuration of FTP access of the hosting.
Secondary FTP accounts:configuration secondary FTP users.
Mail accounts:set up email accounts.
Configure folders:protection configuration and folder permissions.
Antivirus/Antispam:configuration and activation of Antivirus and Anti-Spam protection.
Statistics data:access to AWStats statistics and access data.
MySQL data:MySQL configuration of the hosting.
MySQL users:MySQL secondary user settings.
Alert options:set up service alerts.
Install CMS:install CMS to hosting, WordPress, Joomla, Moodle, etc.
Configure aliases:management of the accommodation alias or add a new alias for accommodation.
Configure errors:configure the list of configurable accommodation errors.
Web form:activate sending accommodation forms.
Multidomains:multidomain configuration of the accommodation.
Configure subdomains:management of accommodation subdomains.
Unzip files:decompress files from the accommodation (zip, rar, gzip, tgz).
Cronjobs:configuration of the CRONJobs of the accommodation.
View errors:web error log viewer and hosting php log.
Mailman:add Mailman mailing lists.
Newsletter user:user settings newsletter.
SSH/sFTP: SSH and sFTP user configuration.
Show mialias.net: shows the status of the temporary subdomain mialias.net.
White mark panel
You can access the white label panel (Management) through the domain http://midominio.com/gestiona, to access use the access data you specified above.
The white mark panel looks like the one shown below.
Related Articles
How to manage the design of the white marker of multihost service hosting
In cdmon, we have theWhite mark panelin order to make it easier for our customers to manage their accommodation without having to access the main cdmon Control Panel. We can customize this panel with colors and the logo of our brand. To do so, we ...
ConnectiLogs Panel | Query Generator
The query builder is a tool that allows you to explore your ConnectiLogs data in a customized way, without needing to use code or technical language. With it, you can create filters, combine conditions, visualize results with different types of ...
ConnectiLogs Panel | Log Management
What is ConnectiLogs? ConnectiLogs is the visualization, analysis, and exploration platform for activity and security data from cdmon products. Its goal is to centralize all the information generated by the different services in order to facilitate ...
How to manage our web hosting
With the web hosting "Control Panel", you can easily manage your hosting. The panel consists of a section with hosting information and different sections with tools. To access the hosting management panel, in the "Basic service list", click on the ...
How to set up a web redirection by URL
To set up a URL web redirect from your Control Panel, you must have the domain, hosting, or both contracted with cdmon. There are three possible ways to create the URL redirect: through "Domain Management", through "Hosting Management", or through ...
